5.0 Stumble/Hesitation around 3000 RPM
I have a 95 GT 5-speed and it doesn't have the takeoff power it should. Ive replaced the cap, rotor, plugs and fuel filter and that didn't help at all. Right around 3000 RPM it will stumble and act like it don't want to accelerate any faster. If I try to push it past that sometimes Ill get a little popping back through the throttle body. The Check Engine light comes on sometimes and goes back off when restarted. Ive tried to have oreillys and Auto Zone read the DTC but nobody's scanner will communicate with the car. The car is really weak at first start and gets better after warm-up. The car has no cats and I have installed a short belt to bypass the smog pump. I would appreciate anyone's help or suggestions < thanks
i had a similar problem when my car was cold it would surge under load but it cleared up as i accelerated. and then wouldnt do it when the car warmed for me it was the tfi module.. but try to run codes first. check on ebay for a code reader. also check fuel pressure
Not trying to jack the thread, but my car is having very similar problems to what you stated. Is there any way to test the tfi module?
here is a site to check for no start http://sbftech.com/index.php/topic,588.0.html
but you can take it off and have autozone check it. but its hard cuz i think you want to test it when its hot
Are your spark plugs gapped correctly. Make sure to use a feeler guage and not the cheap gapper tools that places like auto zone sells.
Also check to see if your timing is correct. This will definitely cause issues if it is off.
Maybe an exhaust leak. This could cause power loss issues.
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
