installing kill switch
Which would be easier to kill, the battery, starter, or fuel pump? An how would I go about installing a kill switch for either one of these? I am installing one for theft prevention.
Which will be best to do the inertia switch or just the fuel pump. And is there any link on how to install the switch for the fuel pumpo cutoff? And where eould you guys say is the best place to hide the kill switch?
Most people put it under the dash some where you can hide it. Maybe even in the glove box or ash tray. All you have to do find one of the wires, more specifically the ground, cut it, lengthen it, add the switch and your off. To run less extra wire the fuel pump relay would be the easiest one to do.
if you want, I can show/tell you guys how to turn your cig lighter into the key to the starter kill. simply pop it out of the socket and it will not start and doesn't look any different, take it with you if you want or just leave it there but with out it pushed in it will not work.
