how will this cam for my combo?
Old 08-05-2005, 08:38 PM
djj624
djj624's Avatar
Default how will this cam for my combo?
The cam is a Lunati 536/536 224/228@50 with 112 lobe sep.. With 1.6 rockers.. The setup is a 306 with forged flatops, 10.1 comp, gt40p heads, trick flow valve springs, performer rpm intake, barry grant 650 speed demon, long tubes, off road H, and cat back.. Is it a good low end, middle or top end cam? will it be lumpy or pretty much stock?? will it provide good gains over the B303 that was in the stock motor? Thanks i appreciate your time..
__________________
90 LX
(THE PROJECT)
djj624 is offline
Old 08-05-2005, 09:10 PM
razarr69
razarr69's Avatar
Default RE: how will this cam for my combo?
I would say all the power with that cam is prolly a good power maker up to about 6000 rpm give er take considering the lift it has. It should be lumpy because the stock HO cam is 444/444 266/266 so thats a pretty big jump. You aren't going to have as much low end with this cam as the B303 but there should be a lot more top end in it.
razarr69 is offline
Old 08-05-2005, 09:19 PM
Quik
Quik's Avatar
without port work GTPs dont like over .500 lift also with a cam with those specs it will be more of a mid to topend cam. bottomend will suffer and will need a stall or if a stick a good feel for teh pedal.
Quik is offline
Old 08-06-2005, 10:31 AM
vfast
I ♥ Acer
vfast's Avatar
it's not a good choice..a daul pateren cam is the why to go....you need more lift on the exhaust side try the 533/544 cam
vfast is offline
Lethaldosage423
10-19-2015 12:12 AM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: how will this cam for my combo?
