Another timing question????
Old 06-19-2010, 12:07 AM
1990boostang
1990boostang's Avatar
Default Another timing question????
Well im back.. I got out of the Mustang's for a while and went to the bowties but im happy to say that im back..... I just recently bought another foxbody and im looking to see where i would benefit the most timing wise. Here are the mods:
302 roller bottom end with forged flat tops
E7 heads
b303 cam
gt40 upper and lower
ford motorsport headers
24# injectors
C&L maf
bbk powerplus fpr
75mm t/b and egr spacer
MSD 6al-2
I am just wondering what would be the best timing for that set up. Its at 14*btc now. Always run 93 octane
Also have a 125 shot but never sprayed it yet and what would be best for timing spraying it.
1990boostang is offline
Old 06-19-2010, 05:56 AM
AdderMk2
Banned
AdderMk2's Avatar
depending on your compression ratio, you might be wasting money on the 93 octane.
Get some real heads and a maf that is worth more than a log of poo, and youll see a major jump in power.
and I'd be running 12°...
125 shot, start around 8°
AdderMk2 is offline
Old 06-19-2010, 08:44 AM
nitrous_bob
nitrous_bob's Avatar
agreed, id run 87 octane and 12* timing. you'll probably make more power
on the 125 jets, i'd go 10* timing and 93 octane
but for everything you should powertime... all cars are different
start low and make runs at the track, note the ambient conditions. temp, humidity etc.
bump 2* per run and where you make the highest mph.. not ET... is your optimum timing for that weather.
do the same on the smack, but start about 8* and go from there
you will slow down b4 you see any ill effects of detonation
fyi, on 80 dry, i use 87 octane and about 12* timing. unless it's hot... i take more timing out. have gone as high as 14* timing on 87 octane, but it was nice and cool and at night
but i also know my car pretty well, so i dont recommend it
nitrous_bob is offline
nitrous_bob
what gears do you have? those 28's are too tall unless your using 4.30's
Old 06-19-2010, 09:59 AM
1990boostang
It has 3.73s. It not the same foxbody listed in my sig. This one has hoosier quick time 26x10x15's
Old 06-19-2010, 12:22 PM
Bubba 95SN
Bubba 95SN's Avatar
Welcome back from the darkside. Bubba
Bubba 95SN is offline
Old 06-20-2010, 09:42 AM
nitrous_bob
perfect.... better if you had 4.10's , but shorter tires are HARD to find.... and kinda expensive
Old 06-20-2010, 01:46 PM
.boB
.boB's Avatar
Most SBF's do best with about 34-36* total timing. Most of the time, you don't get much extra power by adding more, but you do run a higher risk of detonation.
Set your base timing with a vacuum gauge; set it where the vacuum is the highest. If you don't have a vacuum gauge, you can use a cup of water. Set it on the fender, and set base timing where the water is smoothest.
From there, add enough mechanical advance to get you to the 34-36* mark.
.boB is offline
CarrieS
09-01-2015 01:00 PM
GimpyHSHS
08-29-2015 06:30 PM
Calizic
08-28-2015 01:46 PM
stormesixx
08-25-2015 09:11 AM
ding56
08-14-2015 02:40 AM
Quick Reply: Another timing question????
