running rich problem
ok so i have a 89 mustang 5.0 with an e303 cam bbk cold air intake bbk underdrive pullies full exhaust and thats about it when it comes to engine modifications it is also an automatic and has 3.73 gears in it and i recently got a check engine light come on but im not able to pull the code and it is running unbearably rich o actually calculated the mileage and im getting about 4 mpg and i really cant think of at could be wrong with it if anyone can give me help or a point in the right direction i would greatly appriciate it thanks guys
If the check engine light comes on and it starts running extremely rich, I would guess if you get the code, it will tell you your problem. You can check the code yourself with just a jumper wire and a 12v test light.
Could be a fuel press problem. When I first put my S/C on I had the bucking and surging problem. I turned the fuel reg up and it helped. But with the ECU not communicating to the scanner I would try a friends ecu or a new one. My brothers solous could not read codes on my old ecu. I replaced the computer and the CEL went away and the hard starting went away. I know that a ton of people on this forum recomend not changing the ECU but when it is not talking to the scanner what else you gonna do?
yea i ordered one from work bout 4 days ago so it should be in any day now and i did replace the fpr and it help with the surging at stop lights and after checking everything but ripping the motor apart the ecu was the las thing i could think of i posted this just to see if anyone else has had the same problem cause a cause my buddies dad which is a mustang nut and knows everything there really is to kno said even him hasnt seen a mustang run as rich as mine lol
