belt run & motor tilting???
Old 06-21-2010, 09:32 PM
84gtcustom
84gtcustom's Avatar
Default belt run tight & motor tilting ???
2 Q's
1. my belt run using a Pro 5.0 PS bracket up to where the AC was. using a 71.5 belt the tensioner is tilted back ALLLLLL the way. is this right? Pro 5.0 was NO help on the phone with any Q's. I am running BBK? UDP. after sitting for 2 days the belt is only 1/8'' from rubbing now.
2. is my motor tilting? I am just putting, a 98 explorer lower, the new motor back in, but it does'nt look right. All mounts are snugged tight to the block, the frame & tranny.
Where did I go wrong? (other than buying UDP's. :] )
84gtcustom is offline
Old 06-21-2010, 09:44 PM
84gtcustom
84gtcustom's Avatar
another pic
Old 06-21-2010, 10:55 PM
AdderMk2
Banned
AdderMk2's Avatar
you didnt get it in the frame straight... unbolt it and wiggle it straight... not exactly hard
AdderMk2 is offline
Old 06-22-2010, 11:03 AM
nadrepadre
nadrepadre's Avatar
mines doing the same thing. took the car in to school and put it up on a lift. here i see the oil pan on one side is resting on the steering rack/k member. loosened the mounts and straightened it and took it home. Its back on the pan again.
nadrepadre is offline
Old 06-22-2010, 04:36 PM
84gtcustom
84gtcustom's Avatar
ur talking about the motor mounts to the K-member right?
Old 06-22-2010, 04:37 PM
84gtcustom
84gtcustom's Avatar
I'll check this when I get to it tonight. thanks
Old 06-22-2010, 04:38 PM
84gtcustom
84gtcustom's Avatar
any help on the belt run? anyone else using the pro 5.0 power steering mount?
Granatelli Sales
01-20-2020 12:34 AM
carid
07-08-2016 09:55 AM
musnicki
09-23-2015 07:11 AM
Luke9222
09-04-2015 06:46 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: belt run & motor tilting???
