Rear end questions
Rear end questions
Hello, Well I no longer have the car in my sig. haven't had it for about 3 years now LOL. But I did just get a 90GT (Being converted to a LX) I hate the GT body kit. Well my new project is going to be a drag car. It is currenty in the body shop getting painted (Flat black of course) I was going to keep the 8.8 rear end.
My question.. How much power can a 8.8 Take? I was going to get some FR gears 3.70's spooled with some stonger axles.
The engine set up is supposed to have around 500 N/A.. And if it doesn't run what I want it to.. well I will spray the SH*T out of it...
save yourself $500 and put a real tach in there. i can pretty much guarantee your trapping at 5300-5500 rpms
stock tach is way off... and gets worse the higher the r's get, if for some reason it is tach'ing too high, id get a 28" tire b4 swapping gearsets
+1 on 4.10's, 3.73's with a 28 inch tire ??? that sounds crazy. why not leave it stock and 26 inch tire for that matter ???? something is not making sense.
Well I haven't ordered my gears yet and it sounds like I need to get some 4.10's. Is there any difference between the automatic and 5speed final drive ratio. I'm pretty sure the trans I'm going to be running is only 1:1 ratio in final drive.
so yes they are the same
c4 , c6 are 1:1 as they are only 3-speeds
good call on the 4.10's, you WILL NOT BE DISSAPOINTED , it'll feel like adding 100 hp or so
good choice, bare min 4:10's using those antiquate old shoolers formulas such as the ole carb cfm calculation is just plain....well you know.........watched a guy today with 4.30 gears and 26 inch tire and he's trapping 130, so you can easily do a 4.10 -4.30 gear as long as the motor can turn some rpm
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
