Stalling problem
Stalling problem
Hey guys, I'm needing some tech help. When I plug my mass air in and drive the car it will usually stall when I press the clutch in while driving. If I let it sit and idle with it plugged in it will idle for a while and then start going up and down then stall. If it is unplugged the problem goes away for the most part. Doesn't stall when driving, maybe a little bit of up and down at idle but it clears up. Any ideas/things I can try to resolve this?
Yeah. It worked fine a couple of weeks ago. I pulled my lower intake to fix a misfire and now this. Sounds crazy but could me blocking the egr holes in between the head and intake cause something like this? I also put on a new Accufab throttle body.
trashxtrash
09-20-2015 10:49 PM
TfcCDR
09-14-2015 12:08 PM
