fox fuel tank strap removal...?
Old 07-04-2010, 04:51 PM
coondogg
coondogg's Avatar
Default fox fuel tank strap removal...?
You ever notice how a little project (bad fuel pump) turns into a major problem (replacing everything)? Since I had everything apart, I figured that I should replace the tank straps too but I'm not having much luck removing the old ones. Does the pin slide out of the loop in the strap through the holes on the mounting bracket? I'm not having much luck getting them out... :/
coondogg is offline
Old 07-06-2010, 08:42 PM
coondogg
coondogg's Avatar
lol, yep. it just pushes out once the rust breaks free...
coondogg is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
Sixx
10-05-2015 07:36 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: fox fuel tank strap removal...?
