PA C-4 INSTALL HELP!
Old 07-07-2010, 10:41 PM
john89gt
john89gt's Avatar
Default PA C-4 INSTALL HELP!
Has anyone installed the PA C-4 in a 87-93 mustang? I have a '92 with a PA C-4 to go in it. Can't seem to get a hold of the guy I bought it from.The guy I bought the transmission from said you have to have a mount from a newer mustang that shifts the transmission forward. I have the steeda piece that goes between the drive shaft and rear end. I could sure use some help with this. I just hate to get started and have to stop. Thanks for your help.
john89gt is offline
Old 07-08-2010, 07:39 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
is your issue with driveshaft length??? or crossmember issue???
mjr46 is offline
Old 07-08-2010, 03:06 PM
john89gt
john89gt's Avatar
OK looked on your profile so I will say Mike. Mike I completed a little search on the Internet and think I might have found what I needed. I have the Steeda piece that goes in between the drive shaft and rear end. My question was meaning the cross member but found something that said to grind the welds off and slide forward. Do you know if this is correct? No replies so I posted what I located online. Also......thought maybe I may have posted in wrong section so posted 5.0 tech. I don't Know if you have the power to merge the two threads together? OPPPS!
john89gt is offline
Old 07-08-2010, 03:28 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
you should be able to grind the welds off your stock x-member and slide it where you need it
rmodel65 is offline
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
09-10-2015 08:39 PM
Quick Reply: PA C-4 INSTALL HELP!
