The electronic should be fine, I don't know (because I'm ignorant) if the 85 mph speedo will work right or be off (should be fine) But the electronics are the same
This is not the case. In 1990 the wiring in the plugs under the hood changed a bit. you can make it work but you have to repin the harness under the hood. (the two round cannon plugs on the driver side)
i c well if as a last resort i might try that but im looking into a 1992 cluster from a guy over at the corral forum
The shape and mounting bolt locations of the 87-89 and 90-93 models are different. Not only will it not exactly wire up correctly, but it won't bolt in, either.
As Mattdel said, no the 87-89 cluster will not work. They will plug in but you will experience many issues. The first and biggest being that your car will not charge. I do know this from first hand experience.
that sounds undertandable im still looking for a 140mph cluster for my 91 i thought i had a deal but he hasnt replied maybe he will soon
