Sn95 swap for 91 coupe
hey guys ive recently gotten a 91 coupe and it was converted to 5 lug the cheap way now i want to convert it the right way by doing the sn95 swap,the rear has the ranger axles but i just want to work on the front for now but my reason why iam posting is i need a list of what would i need to help me get this done thanks guys
only if you are going all wheel disc then you will need the BB, a proportioning valve, master cylinder, that block under the master (forgot what its called), new rear brake lines, new ebrake cable, north race car brackets for the calipers, rotors, calipers.
http://northracecars.com/Brakes.html
or you could just keep the drums on the ranger axles and save yourself the hassle..
so here is my list i comprised a while ago:
'83-'92 ranger/bronco II drivers side axles from 4cyl or 3.0L with drums
94+ GT/V6 10/84" rotors (2)
94-98 GT/V6 calipers (2)
94-98 GT/V6 caliper brackets (2)
spindle to caliper bracket bolts (4)
94+ spindles (2)
hubs (2)
hub nut(2)
dust cap (2)
dust shield (2)
SS brake lines from Maximum Motorsports
sn95 ball joints into the stock arms or use a 0.330" spacer on the fox ball joints
4 more lug nuts
5 lug spare
94+ spindles (2)
hubs (2)
hub nut(2)
dust cap (2)
dust shield (2)
4 more lug nuts
5 lug spare
Matt's 95 Stang
10-05-2015 07:16 AM
