93gt starting problem
alright i have a 93gt the wiring has been screwed with and in the process of replacing it but i have a weird starting problem with it. whenever it is cold it starts right up, but whenever i run it for a while and shut it off and try to start it again it wont start, but when i pull the first two injectors it will start. i have no clue to what the problem is and could it be the egr?
what wires were screwed with, we need the colors and components they go to.
2. when you say start, you meen the starter will not MOVE. OR the starter does move at a normal fast pace, but the car dont run.
well the wires behind the dash and the starter turns the engine over normaly and wen its hot it will fire a little then it just floods itself out (smell gas really bad) then i have to unplug the first two injectors for it to start.
KEM Motorworks
08-14-2015 10:13 PM
