headlights turn off after 20 mins
If it shuts off and comes back on later then the switch has a breaker or there's one somewhere else in the system.
As a general rule of thumb in any electrical system, if it shuts off and then comes back on after a while, an auto resetting breaker was tripped. They trip from too much heat usually caused either by a short or too much current draw.
I had the same thing happen to my mustang many years ,15 to 20,ago.It turned out to be the multifunction swich wiring .It controls the bright lights ,turn signal, and wipers.When the light went off and on you could move the light swith from dim to bright lights and the lights would go back on eventually.
switch does not have a breaker guys!!!!!! el-101- when such occurs in a system, as an electrical circuit heats up things expand, and if there is high resistance in a connection, often the added heat will cause just enough expansion to break the circuit/cause an open and as it cools circuit contracts/shrinks and closes the open = no general rule of thumb in that = simple el-101 knowledge, know your circuit construction first before assumptions
yes. the fix is adding a relay that can handle the current. if mjr's link is too gray and difficult to read, use this.
http://www.corral.net/tech/maintenance/foglights.html
same thing, better pictures.
