Oil is way overfull and smells like gas
Old 08-08-2010, 10:29 PM
  #21
enix187
enix187's Avatar
Well five quarts doesn't do the job on mine no matter what you say, so go ahead and have the last word and enjoy feeling right, and go ahead and make a witty comment too, its all good
enix187 is offline
Old 08-08-2010, 10:49 PM
  #22
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
No no, go ahead and explain yourself. Why doesn't the 5 quart capacity that everyone else uses doesn't do the job?
projectresto83 is offline
Old 08-09-2010, 01:00 AM
  #23
67mustang302
67mustang302's Avatar
Stock capacity is 4 in the pan plus 1 in the filter for 5 quarts total. If your dipstick says otherwise then the dipstick is wrong and needs to be properly set.
67mustang302 is offline
Old 08-09-2010, 08:52 PM
  #24
Bubba 95SN
Bubba 95SN's Avatar
Gasoline is inserted in side of car .. do not put gas into oil fill cap on valve cover.
Bubba 95SN is offline
Old 08-10-2010, 05:10 PM
  #25
Readyakira
Readyakira's Avatar
Capacities
Engine Oil:
All except 4cyl turbo
Without filter change: 4qts
With Filter change: 5qts
4cyl Turbo
Without filter change 4.5qts
With filter change 5.5qts
um, looks like even if you have a 4cyl turbo and put 6qts in you have too much. Unless you do not have stock oil pan on it.
Either way if the oil is smelling like gas you have a problem. How long does it take to get this way? It would take quite a bit of gas to make the oil level noticably.
Readyakira is offline
Old 08-10-2010, 07:14 PM
  #26
fordboy5.0
fordboy5.0's Avatar
uh do you have low oil pressure ennix just wondering?
fordboy5.0 is offline
Old 08-10-2010, 11:06 PM
  #27
enix187
enix187's Avatar
since you asked a question, nah, I have terrfic oil pressure in my 93, above half. I've stopped arguing my case here because I'm fully aware of what the manual say's goes in the car, the simple fact is, the oil light is on at 5 qts, and the dipstick reads low from the full mark. This thread has been severely hijacked for this ****, sorry op.
enix187 is offline
Old 08-11-2010, 06:46 PM
  #28
fordboy5.0
fordboy5.0's Avatar
just tryin to help fellow mustang owners one thing that can happen from being over full is ur crank will splash against the oil and cause air bubbles and the oil pump doesnt pump air very good (low to no oil pressure)
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
Sixer4Life
10-12-2015 04:26 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Oil is way overfull and smells like gas
