5.0 conversion, no start, no fuel
Old 08-21-2010, 08:50 PM
dansk
dansk's Avatar
Default 5.0 conversion, no start, no fuel
Fired up fresh motor with starting fluid, runs great if I keep spraying. Have fuel pressure to fuel rails. Can anyone steer me in the right direction as to where to look? BTW, engine is dropped in a Miata.
Thanks, Dann
dansk is offline
Old 08-25-2010, 02:47 PM
Tims 88GT
Tims 88GT's Avatar
One bad bad idea to run a motor on just starting fluid. What year engine is this, mass air or sd? Need more info bud.
Tims 88GT is offline
Old 08-27-2010, 04:01 PM
OCHOHILL
OCHOHILL's Avatar
Just theorizing here. I don't know my stuff. If you have good fuel pressure and the injectors aren't firing then you should look at why they are not firing.
Power to PCM?
harnesses connected?
does the pcm read rpm from the crank trigger? It may not know the engine is even turning over.
OCHOHILL is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
drfister
05-03-2018 10:38 PM
YoungStangsMan
09-05-2015 07:01 PM
1st 4 eyed fox
08-24-2015 06:56 PM
jpplaw
08-22-2015 09:29 PM
Quick Reply: 5.0 conversion, no start, no fuel
