gt40p questions
gt40p questions
hey everyone i just pulled some gt40p heads off a 98 explorer and was wondering if i would run into any problems installing them, and all i got was the heads the upper and lower intake with injectors, mass air and throttle body can i use these parts? and i did not grab the pushrods or headbolts. and i may be camming it also so any info on the heads would be appreciated thanks.
the maf will be useless to you, the TB will require modification, the injectors are the same as your stockers... and you better bring the heads to a machine shop for a cleaning, pressure check, and surface mill.
thanks adder and im going to rebuild the engine so i will get the heads freshened up. so mostlikly i will have to get a aftermarket maf and modify the tb for it to work and thats it? i hope i didnt make a mistake and not grab the pushrods.... and what kind of cam would you recommend? it will be mostly a street/strip car so i dont want something that gets 10mpg u know thanks for tha help.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
