Questions on trickflow r intake
Old 09-03-2010, 08:17 PM
orange5.0fox
orange5.0fox's Avatar
Default Questions on trickflow r intake
Well I started my car just the other day, first time since i have put afr165 heads trickflow r intake and a master power t70 turbo on it. Now when it idles it makes a high pitched noise sounds just like a vacuum leak, thought it was till after I sprayed every thing with carb cleaner and smoked the intake to try and find the vaccum leak. Only at idle does it make the sound, reved at all and there's no noise. I was just wondering if anyone has used or is using the trickflow r series intake manifold and does it make any noises just wondering cause if you put your ear on the top intake it sounds like the noise is right inside of it. Just have no idea where it would be coming from anymorAlso my vacuum ports on the under side of the top intake manifold are removed and have been welded up from the previus owner of the intake don't know if that would matter or not just thought I would throw that put there. Thanks for any input
orange5.0fox is offline
Tivo304
08-28-2023 12:19 PM
Luke9222
10-22-2015 11:55 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Questions on trickflow r intake
