all done with tranny install clutch adjustment issues >.<
Old 09-05-2010, 10:15 PM
chilywily72
chilywily72's Avatar
Default all done with tranny install clutch adjustment issues >.<
Ok guys I got the new clutch and the rebuilt tranny back in my 93 gt. I put a steeda quadrant and double hook quadrant with a firewall adjust in as well. The adjuster is all the way out and there is still some play in the pedal. In the instructions it said to use the hook closest to the firewall so i did is it ok to switch to the further hook at the top of the quadrant or should i just adjust the nut further in at the clutch fork?
chilywily72 is offline
Old 09-05-2010, 10:21 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Adjust the cable at the clutch fork. Set the firewall adjuster about an inch or so from the firewall and take the slack up at the fork. Then use the firewall adjuster to fine tune the pedal feel and clutch release. When finished you should have the clutch releasing/engaging about 1/2 way through the travel and you should have about 1/16"-1/8" gap between the FW adjuster and cable end when pulling out on the cable.
Boss_Hotrod is offline
Old 09-05-2010, 11:59 PM
302army187
302army187's Avatar
+1 adjust at the clutch fork first.
boss wrote it up well
302army187 is offline
Old 09-06-2010, 10:45 AM
chilywily72
Awesome thanks guys! Am i right using the bottom hook on the quadrant though or should I use the top hook?
Old 09-06-2010, 09:48 PM
Boss_Hotrod
I believe that when using the FW adjuster you're supposed to use the hook closest to the firewall.
Old 09-06-2010, 09:52 PM
chilywily72
yea thats what the instructions say so that should be the bottom hook correct?
djbigskrilla
09-20-2022 01:04 AM
Urambo Tauro
12-17-2016 03:30 PM
squishbang
12-04-2015 02:29 PM
Jskeezy84
09-08-2015 01:40 AM
ponyride00
08-12-2015 01:57 PM
Quick Reply: all done with tranny install clutch adjustment issues >.<
