Horrible starting noise - shaved flywheel teeth
This is latest in a very long running issue.
5+ years ago I was adding metering block to secondaries of my Holly carb and something didnt go right. Cylinder flooded and I got a hydraulic lock.
The next week I get offer to take 2 year assignment in CA, I get car started with a slight tick that goes away once oil pressure is up (70PSI) and car goes into storage. After that car goes into garage for 3 1/2 years because new house has more pressing needs.
Good news is that 2 weeks ago I spend some time draining cas and car fires right up, love that Sta-bil. Drive around the neighboor hood EVRYTHING feels and sounds normal.
So here is the issue, there is a horrible knocking noise during startup which stops once the car is running.
First thought is this is related to the hydraulic issue 5+ years ago. I have never resolved what if anything occured during this event and durring this startup the engine didnt produce any noise.
I went through and re-adjusted the rocker, everything looks good but noise is still there. I pulled the starter, it looks fine but I find that I have 8 teeth on the flywheel that are missing.
http://s221.photobucket.com/albums/d...t=DSC01806.jpg
What I'm trying to figure out is if this was due to the issue 5+ years ago or related to the recent start up (although I turned over the engine by hand)?
