do not double post, thank you
I am having a 347 with eagle forged crank & hbeam rods comp cam .555/.565 xtreme energy cam 1.6 roller rocker arms rhs pro action heads 10to1 compression edelbrock rpm II intake 42lb injectors 70mm throttle body 255lph fuel pump. It has a 5speed in it now what would be a good transmission and clutch to use and what rearend gears should i run. Its going to be use for mostly cruising and track once in awhile.
2 threads of the same nature in the same section and the fact that they are also in the wrong section = your threads are non tech = will not get you help = quite the opposite.....please abide by forum rules , thank you
