**ROUGH IDLE/TIMING**
oNE DAY MY CAR WOULDN'T TURN OVER. hAD TO REPLACE THE FUEL PUMP. oNCE THE FUEL PUMP WAS REPLACED, i STARTED THE CAR AND IT WORKED. iT WAS RUNNING. THE PROBLEM IS THAT THE IDLE IS VERY ROUGH AND IN THE ENGINE COMPARTMENT i HEAR A POPING NOISE. sOUNDS LIKE THE NOISE IS COMING FROM THE K&N FILTER AREA. pRY TO THE FUEL PUMP FAILURE THE CAR IDLED AND RAN GREAT. i REPLACED THE FUEL PUMP AND NOW IT RUNS LIKE ****.
aNOTHER QUESTION, THE SHUT OFF VALVE IN THE TRUNK, SHOULD THE RESET SWITCH BE UP OR DOWN. i DONT HAVE A SWITCH WHERE U PUSH DOWN N IT COMES UP ON ITS OWN. iF YOU PUSH DOWN ITS STAYING DOWN. USE A SMALL SCREWDRIVER TO BRING IT UP... hELP!!!!!
