oil pan sensor/plug
Old 09-11-2010, 09:55 PM
byronpen
byronpen's Avatar
Default oil pan sensor/plug
I have a 1985 stang 302, What can I use to plug the oil pan sensor hole, This old lady is hitting the dirt track
byronpen is offline
Old 09-12-2010, 12:10 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
ummm the low oil sensor maybe???........
projectresto83 is offline
Old 09-12-2010, 12:22 AM
mrspeaker
mrspeaker's Avatar
I used a generic oil drain plug 20mm x 1.5..if you go to autzone ask for a Subaru STI drain plug from the back.
I did this because my oil sensor was leaking not from the $2 gasket, but from the little wire in the middle and I didn't want to spend alot of money on a new unit.
mrspeaker is offline
Old 09-12-2010, 09:30 PM
pete88gt
pete88gt's Avatar
some RTV around the outside of it, if you're cheap and need it fixed
pete88gt is offline
Old 09-15-2010, 12:12 PM
.boB
.boB's Avatar
Since you're hitting the dirt track, you might want to add an oil temp gauge. You can get an adapter from FortesParts.com
I wouldn't use silicone, it won't hold up.
.boB is offline
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: oil pan sensor/plug
