car wont start now
car wont start now
so my coil went bad and i took off the old and put on a new stock one and the car wont start now. it wont even turn...the car would turn when i had the old one in but now it just makes a noise.
I also bumped the fuse box and some may have fallen out. would a fuse have something to do with the car not starting?
I dont see how the coil is the problem because i just unplugged the old and plugged in the new one.
alright before you get a slew of enraged people coming after you let me try and help you out. First thing you need to do is to check and make sure all your fuses are in and good. then you follow this nice little instruction booklet (its a webpage i know) and see what you can find out with it. I can't remember if it goes over it but to check your solnoid just touch a jumper wire to the little lead on the top of the solenoid from the positive battery, the motor should turn over.
http://www.stangnet.com/mustang-foru...-off-coil.html
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
