Problem when getting on it
When I get on my car and rev it above 4K rpm it always leaks oil from somewhere I'm thinking its the bottom of the dipstick?
Does this sound right? If so how do I fix it?
Well there is smoke and it smells like burning oil lol at first I thought it was a leaking valve cover but a friend of my has a V8 s10 and when he dogs it oil comes out the dipstick too
Have you checked the back of the manifold? I mean if it only happens while your reving up...
Is the oil dripping on the exhaust smoking or is it blue smoke?
You should clean your engine then find your leak searching the top down instead of assuming where its from
The oil gets on the exhaust and starts smoking
If it's coming out the dipstick, that usually means excess pressure in the crank case. Too much blow by, caused by worn rings. Check your PCV system.
I know this flies in the face of common wisdome, but you might try and improve ring seal with some Restore oil additive. I know, I know, "it's all snake oil". But I'v used it on old engines to get me through until I can overhaul them. It worked. Not a miracle, but it did help.
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
