Help! Swapped my trans and now my ignition switch wont start car.
Old 10-02-2010, 02:54 PM
Jfsram
Jfsram's Avatar
When you cross the two big lugs on the starter solenoid you are actually bypassing TWO things. All this tells you is the starter is ok.
To engage a starter solenoid you need 2 things. A signal from the ignition switch when it's in the start position and a signal from the clutch switch. When you have both, you have cranking.
Jfsram is offline
Old 10-03-2010, 12:00 AM
nightmare90gt
nightmare90gt's Avatar
Originally Posted by mattdel
no, you just got lucky. you didn't verify that you had incoming power from the ignition switch, telling the solenoid to switch. don't spread bad info if you're just guessing.
please tell me how i gave bad info when i wasnt guessing cause like i said i just went threw this so i know a little of what i am talking about. if i am wrong i am wrong but that is how i checked my starter solenoid and found it was bad. not bad info just lets you know that your solenoid is bad.
nightmare90gt is offline
Old 10-03-2010, 07:54 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Mattdel is correct and you did get lucky. Not saying the soleniod isn't bad, but that's the incorrect way to test and verify it.
To the op, it's a coincidence, swapping the tranny would in no way have any direct result in the car not starting.
PRO50SC is offline
Old 10-03-2010, 07:20 PM
nightmare90gt
ok i will admit i am wrong but can you fill me in on the correct way please. also for the op
Old 10-03-2010, 10:47 PM
Jfsram
Jfsram's Avatar
It was explained in the first reply on the 2nd page.
Jfsram is offline
Old 10-04-2010, 04:58 AM
Lance1
Lance1's Avatar
It's wasn't the starter solenoid as I was able to jump the car from the solenoid. I will get the clutch switch done today. I appreciate the passion in the replies. All of you are helping me tremendously and I thank you for all the help! I"ll keep you all informed! Check back tomorrow for the update. Thanks again.
Lance1 is offline
Old 10-04-2010, 12:40 PM
Lance1
Lance1's Avatar
JFstram,
BY "clutch switch" do you mean the clutch pedal position switch? I've called some shops like auto zone and advance auto and they have no listing for it. Can anyone let me know exactly what it is or send me a part number. Thanks
Lance1 is offline
Old 10-05-2010, 12:08 AM
mattdel
mattdel's Avatar
On the clutch pedal assembly itself, you'll find a switch with a 2 wire connector on it. Unplug the connector from the switch, and jump the 2 terminals with a paperclip or a small wire. If the car starts, you found the problem.
mattdel is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
jpplaw
08-22-2015 09:29 PM
Sandmanbjj
08-21-2015 12:38 PM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: Help! Swapped my trans and now my ignition switch wont start car.
