I Have No Clue!!
I Have No Clue!!
'90 GT When you unplug the Mass Air Sensor it will idle, plug it plug and the car dies. Problem 2 has a backfire after you rev it up. Can these 2 problems be link and what could be the cause of them? Thanks
id run codes like before mentioned but yes the maf if dirty will make the car backfire. clean your maf sensor. i had the same problem and troubleshot a while with no luck til i cleaned the maf sensor and that was it. good luck
ShaneB26154
35
03-04-2021 04:05 AM
