GM 1 Wire Alternator On Foxbody? - MustangForums.com
Sponsored by:
Sponsored by:
Old 10-23-2010, 10:33 AM   #1
88Mustang351W
Default GM 1 Wire Alternator On Foxbody?
I've been having trouble with the electrical in my car it's not charging the battery I've checked all I know to check and someone said converting it over to a GM 1 wire would more than likely fix the problem, Has anyone ever done this on here and what all is required to do so?
Thanks
88Mustang351W is offline   Reply With Quote
Old 10-23-2010, 10:44 AM   #2
TrimDrip
TrimDrip's Avatar
I have seen them polarized and start charging...Are you sure the alternator is good to begin with?
I bought this and it fits and works great. http://forums.corral.net/forums/show....php?t=1243154 The alternator is new and has a 3 month warranty. He claimed it was the same alternator PA performance sells but with less warranty. Reason being why it is cheaper.
TrimDrip is offline   Reply With Quote
Old 10-23-2010, 11:11 AM   #3
88Mustang351W
I went had the old alt tested it passed but i still bought a new one and still didnt fix the problem
Old 10-23-2010, 12:11 PM   #4
86 5.0L
86 5.0L's Avatar
Quote:
and how is a different brand alternator going to solve this?
86 5.0L is offline   Reply With Quote
Old 10-23-2010, 12:14 PM   #5
88Mustang351W
Quote:
Uhh because I wont have to use any of the stock wiring with the 1 wire alternator.....
Old 10-23-2010, 12:28 PM   #6
Slug Catcher
Slug Catcher's Avatar
Quote:
I went had the old alt tested, it passed but i still bought a new one and still didnt fix the problem
Im not trying to insult you, But try finding the problem. Your just throwing parts at it.
Are you sure the battery/voltage regulator arent fried? Have you even checked the wiring?
Seriously, If you cant figure it out take it to a mechanic. It will be cheaper then throwing alternators at it.
I think its a bad idea to go the "1-wire route" to by-pass the problem, when you dont even know what the problem is.
The repair may be cheaper then you think.
Slug Catcher is offline   Reply With Quote
Old 10-23-2010, 12:35 PM   #7
88Mustang351W
Voltage Regulator on 86 is inside alternator, which is new and battery also is new this is the 2nd one ive looked at the wiring and couldn't figure it out, Don't want to take it to a mechanic car isn't work it to me and I already have a 114 dollar alt I can take back get my money and pay the 75 for the GM 1 wire
Old 10-23-2010, 12:36 PM   #8
88Mustang351W
Oh also I checked all grounds made sure everything was connected securely and replaced battery terminals
Old 10-23-2010, 11:04 PM   #9
Bubba 95SN
Give up, do the blasphemous thing, mate GM to Ford. Henry is rolling in his grave. Brandon as Andy would say "Try to act like you got some smarts, don't do that." Folks here can walk you through this. One wire for dummies.
Bubba 95SN is offline   Reply With Quote
Old 10-24-2010, 03:26 PM   #10
tohoopty
tohoopty's Avatar
i would try to tell you what the problem is but i cant explain it all so im not gonna even try.
tohoopty is offline   Reply With Quote
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 04:23 PM
1994-1995 ODBII Port Urambo Tauro 5.0L (1979-1995) Mustang 6 10-05-2015 09:37 PM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 07:16 AM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 05:52 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 05:26 PM
1987, 351, 50, 95, altenator, alternator, ford, fox, foxbody, gm, mustang, pics, polarization, stock, wire
