T5 help.
Old 11-01-2010, 12:23 PM
amar@uak
amar@uak's Avatar
Default T5 help.
Hi all,
I have a 1995 GT and i'm currently rebuilding the trans. I ordered a kit with new synchros and have disassembled everything from the main shaft. However, the problem is the new cones and blocker rings won't fit together. There is a composite on the inside of the new blocker rings that looks similar to grafite. Do i need to remove this? there is no composite on the old blocker rings and they fit with the cones perfectly. I've looked everywhere for help and even called the company that makes the kit but i've come up with nothing. Any suggestions anyone has is appreciated.
amar@uak is offline
Old 11-01-2010, 06:49 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the composite has worn off the old ones the material should be there
mjr46 is offline
Old 11-01-2010, 07:18 PM
Bubba 95SN
Bubba 95SN's Avatar
Soak blocker rings in Dexron overnight before assembly.
Bubba 95SN is offline
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
NYstang
09-30-2015 09:56 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: T5 help.
