Tach Wiring
Old 11-17-2010, 08:41 PM
rhank88
rhank88's Avatar
Default Tach Wiring
I have an 88' GT with an aftermarket tach that was wired directly to the stock wiring. It jumps around a bit and I've been told it should be wired directly to the distributor.
How do I do this?
rhank88 is offline
Old 11-17-2010, 08:49 PM
a_penquin
a_penquin's Avatar
Jump around by how much?
a_penquin is offline
Old 11-17-2010, 08:55 PM
rhank88
rhank88's Avatar
Not jumping all over the place, just not holding steady. Sadly, I've only driven the car a few times after buying it over a month ago due to transmission problems.
Thinking of things I can get done before I can get to my brother's house where there is a lift and someone who knows what they're doing.
rhank88 is offline
Old 11-17-2010, 09:01 PM
a_penquin
a_penquin's Avatar
A normal engine will not hold steady, it constantly adjusts idle speed. The finer the tach reading the more it will show.
Old 11-17-2010, 09:50 PM
enix187
enix187's Avatar
the negative side of the coil, I can't remember which wire that is
enix187 is offline
Old 11-19-2010, 06:30 PM
nitrous_bob
nitrous_bob's Avatar
do you have an msd ? go to the tach adapter if you do
if not use both wires on the coil.
nitrous_bob is offline
Old 11-19-2010, 06:31 PM
nitrous_bob
and btw... if you have an msd and wanna go coil anyways.... if it has the tfi harness... you now need to use the wires on the harness... not the coil wires
Old 11-19-2010, 07:52 PM
Bubba 95SN
Bubba 95SN's Avatar
Dark Green Yellow tracer is color of negative coil wire
Bubba 95SN is offline
Old 11-19-2010, 11:41 PM
enix187
enix187's Avatar
forgot about the tfi, thinking chevy agian
enix187 is offline
Old 11-28-2010, 03:53 PM
rhank88
rhank88's Avatar
no msd. It shows idle at 2k, but is no where near that. Plus, I was driving down the highway in 5th gear last night going 55mph. The tach showed 4k and then slowly crept a little below 3k and then crept back up slowly. Speed didn't change at all during this change.
I didn't wire it so I don't know where it stands now. Plus, if it matters the motor is not stock. It is a dss 331 stroker carb'd
rhank88 is offline
Quick Reply: Tach Wiring
