broken oil dipstick tube!
Old 04-09-2011, 09:27 AM
jlc41
jlc41's Avatar
Originally Posted by TrimDrip
if you tried for months, I would just pull the oil pan.
I would try an easy-out first.
What he said, and if nothing else the easy out will cause it to break loose then the paint can tool should work.
jlc41 is offline
Old 04-13-2011, 05:01 PM
1986Gutierrez
1986Gutierrez's Avatar
alright so easy out, u think by taking out the header should give me enough room to pull it out?
1986Gutierrez is offline
Old 04-13-2011, 05:02 PM
1986Gutierrez
alright thanks
Old 04-13-2011, 06:09 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
I can't believe you are still fighting with this. If it is that big of a PITA I would just knock it down into the oil pan and just drop the pan.
projectresto83 is offline
Old 04-13-2011, 10:58 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
If you can't get on it I guess I would pull the header.......I know what you have done because I have done it myself. It seems like it came out way to easy and then you find out that it broke off. Luckily, I had the engine out and was going to change the pan anyways.
Only thing I can tell you is that it sticks down in the block a good ways. The thickness of the block that is an inch or better and then a few inches more. If you do get the piece out, it will be about the length of your ring finger....Hopes this helps.
TrimDrip is offline
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
wraith777
09-28-2015 10:49 AM
09-25-2015 06:58 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: broken oil dipstick tube!
