Steering Shaft/k member+rack dilema
The picture if you look closely the rack in the car's input shaft is skinny, too skinny for my stock steering shaft. You can see the rack that came out of the car in the picture, its a lot bigger Which is the OEM power rack that came with my car. It appears hooked up to the rack, but its not.
The rack came out of a 89 racecar. Its a Full Manual Rack from Ford, im sure it wasnt an original rack from that car though. I got it for free and it bolted right up, The threads are narrower for outer tie rods, there tightened almost all the way up with about 3 threads to spare to get wheels pointing straight, but works
The part number on the manual rack is chipped off.
My question is, what are my options here?
AJE Racing K member with coilovers is my setup.
