stock rear lower control arm bushings
Old 11-30-2010, 08:37 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
personally I would get the ones with the adjustable spring perch and urethane bushings on the body side. They will work well for what you want. Then if you need to adjust your suspension for anything in the rear you can.
If you are hurting on money and want something better than stock you can at least go with latemodel's version of the MM's
http://www.latemodelrestoration.com/...r-Control-Arms
You don't sound like your going to beat your car to death at the track so I think they will hold up for you just fine.
projectresto83 is offline
Old 11-30-2010, 08:47 PM
nightmare90gt
nightmare90gt's Avatar
I plan on putting on coil overs would u still put the adjustable spring perch or is it just useless
nightmare90gt is offline
Old 11-30-2010, 09:33 PM
projectresto83
M.A.D. Motorsports
I would go coil overs first then. You can get that kit for just a little more anyway.
Old 11-30-2010, 10:00 PM
nightmare90gt
So should I get the non adjustable one also I plan on making about 500-600 to the wheels so should I be fine with heavy duty or should I get extreme duty
Old 12-01-2010, 06:51 PM
projectresto83
M.A.D. Motorsports
call MM and ask their reps and see what they say
Old 12-01-2010, 07:34 PM
nightmare90gt
i know there website says that the extreme duty ones are good for 600+ so probably them
Old 12-03-2010, 11:15 AM
Jfsram
Jfsram's Avatar
Originally Posted by AdderMk2
not even close...
Its so you can accurately set the Instant Center, and Anti-Squat dimensions of the rear suspension geometry
It is even close. I'll bet 90% of the buyers of adjustable spring perched arms are doing it to raise or lower the ride height of the car.
To the original poster. If you budget just will not allow for new arms. Find a set of used low mileage arms. There are millions of them out there as many Mustang owners installed aftermarket arms on their cars and have the stockers just sitting around.
Jfsram is offline
Old 12-03-2010, 04:24 PM
nightmare90gt
not a bad idea but i will probably just save up and get the extreme duty non adjustable control arms
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
cedarmn
08-28-2015 09:51 PM
Mobiusone stang
08-24-2015 04:08 PM
inyadreems
08-21-2015 09:10 AM
Quick Reply: stock rear lower control arm bushings
