Wiring problems!
Wiring problems!
Just purchased new carb, dist, igition box, and coil. Currently have a 87 mustang 5.0 302 five speed changed from fuel injected to carb. Now just ripped all electrical out and computer junk. Is there a place or someone who can make a custom harness bc ive got no clue on wiring all this started to re wire at the brake booster by taping into and using a chilton diagram of a 1990of the body.
Welcome to the Board!
Oh, for repro parts and all to get your 80's Fox going again, check out these guys:
http://www.latemodelrestoration.com/
They can get just about anything, electronics or whatever, just for your car
You do not need a custom harness for what you need man. The computer controlled harness will be completely eliminated. It is the harness that comes through the passenger side. The harness that comes through the driver side doesn't need to be cut into....unless you get a coil that doesn't use the stock connection. The dizzy and box can be wired in but tapping into a ignition power wire and ran to the dizzy. What box, dizzy and coil did you get? Just ask if you have any questions!
zanemoseley
09-06-2015 12:58 PM
