Vibration questions
If you set TDC by using the piston then yes it will show at zero. If you match the rotor and number 1 plug then you will see your timing.
It looks like the rubber is pushing itself out of the balancer.
yeah I first set it with the rotor and it was sitting at around what would be 40 degrees, so i decided to see what it was with the #1 piston all the way up and thats where it is in the pic.
(yes I do run quite a bit of timing on it...dyno liked it)
yeah i see summit also has an OEM for about 65. Just really unsure why it failed..then again i cant remember if i put a new one on when I had the new engine put in, which if i didnt, would mean that this one has around 150k miles on it...60 bucks sounds like a good start, got an engine stand for xmas, so at least ill know before i yang the engine to reseal it back up (vibration was poppin gaskets left and right on just a few trips)
well i need to change the pan gasket, it sprung a leak last time i drove it with anti-freeze somewhere, and tranny is leaking somewhere as of late also. Im taking off for a couple months and have the wifey half talked into a TKO or astro performance T5, so I figured I would pull both fix leaks and wait for transmission
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
