Ok...all I did was change the oil.
Old 12-25-2010, 10:58 AM
  #31
2tonterror
2tonterror's Avatar
First disconnect the fuel filter. Then take an air line from a compressor and blow the line out going back to the tank. Don;t use too high of a pressure, otherwise you might blow the sock off the pump. Did you check the ground wire to the fuel pump? A little corrosion on the connector will cause a drop in voltage and cause the pump to slow down. You should also check and make sure you are getting a full 12 volts to the pump.
2tonterror is offline
Old 12-25-2010, 12:23 PM
  #32
Dj_Seph
Dj_Seph's Avatar
Originally Posted by Bladerunner
Make sure to use a Ford Motorcraft fuel filter they are the best to use
on your Ford Mustang.
I used Wix. Always had good luck with them.
Dj_Seph is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Ok...all I did was change the oil.
