Cracked Floor???
Old 12-29-2010, 03:01 AM
Five0hFox
Five0hFox's Avatar
Question Cracked Floor???
So I pulled my carped up in my car before I paint so I don't have any interior except the dash to worry about when jamming it. It was pretty rusty on the passenger side. I was using a wire wheel to get some rust off before applying Por-15 on the floor. Then I found this.
Passenger side
http://s20.photobucket.com/albums/b2...t=96f5d0ae.jpg
Also on the driver side
How worried should I be about this? I plan on having full length sub frames welded in. Should I just weld the cracks to seal them and not worry about it?
You can see the location of the crack in this picture. Left side towards the bottom.
Also, regarding the por-15, I was just brushing it on. I used Prep-All to wipe it down after using a scotch brite pad on it. It looked like I was getting real bad fisheyes. If I scuffed the por-15 and re-applied would fisheyes appear again or would it cover them and seal it good? Anyone know?
Five0hFox is offline
Old 12-29-2010, 06:51 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just weld it, I have seen it plenty of times, even 2 of my rides had such my 89 vert was way worse, and I welded it and it worked fine
mjr46 is offline
Old 12-29-2010, 07:36 PM
Five0hFox
Five0hFox's Avatar
322 views and your the only reply haha.
Thanks, I'm sure your right, you always seem to know your stuff! I need to get a plug for my wire welder so I can use it instead of our stick.
Old 12-29-2010, 08:39 PM
9redfox3
9redfox3's Avatar
The results can be Great if done right. I used the "silver" por 15 and than applied Tie-Coat Primer and top coated with a rust oleum red color.... Just do the 'PROPER PREPARATION here ya go ..
http://www.por-outlet.com/faq.htm
9redfox3 is offline
Old 12-29-2010, 09:30 PM
mjr46
mjr46's Avatar
I used my mig welder, a stick/ arc welder would be a pain and you'd have to turn it down low and use a skinny rod, not sure of the type needed, for the welds that often break on my plow iirc I use 6013 but then again that's heavy metal
mjr46 is offline
Old 01-03-2011, 03:09 PM
superstang92
superstang92's Avatar
i agree just weld it
superstang92 is offline
Old 01-03-2011, 04:49 PM
DRAGUL
DRAGUL's Avatar
I had the same thing happen when I owned my 83. I just cleaned up the cracks real well and welded it using a mig. Lasted for years until I sold it. I don't know how true this is, but I was told this was a pretty common problem on the fox body cars.
DRAGUL is offline
Old 01-04-2011, 12:39 AM
ponyponer
ponyponer's Avatar
i welded mine. it was cracking so bad that i didn't even notice it until i was vacuuming and lifted the mats up. i had noticed it for a while before that. it always sounded like something wasn't right, because i could actually hear the exhaust coming up into the passenger side. it was also how i found out my ball joints were bad. it took a few minutes, and i had it done no problem.
ponyponer is offline
Old 01-06-2011, 12:36 AM
Tony71502
Tony71502's Avatar
Mig weld. Tig will burn through, more than likely. I had to mig the driver's seat studs back in on my car. The big bastard that owned my car before must have stood on the clutch and ripped two seat mounts out of the floor.
Welds are stronger than the metal, btw.... if done right.
Tony71502 is offline
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Cracked Floor???
