Z303 cam problem
Old 01-18-2011, 10:08 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Originally Posted by AdderMk2
im pretty sure you have the cam timing mixed up .bob
isnt it retard the cam to increase the power band rpm range?
beat me to it...
reason:
retarding the cam moves the events later into the process IE: a larger cam makes more power up top due to the increase in piston/air speed filling up the cylinders more completely, also the reason they dont do so well down low.
granted with a stock cam it will be a very small difference, but still worth something...
and the OP was talking about advancing the cam by 1 tooth on the gears, not using the adjustable keyways that offer the advance/retard features...
1 tooth = WAYYYYYYYY more than even 8*...
sn95_331_GT_ yellow is offline
Old 01-19-2011, 12:17 AM
.boB
.boB's Avatar
Yes, you're right. Advance moves down, retarded moves up.
.boB is offline
Old 01-19-2011, 01:53 AM
AdderMk2
Banned
AdderMk2's Avatar
I was even polite about it this time....
AdderMk2 is offline
Old 01-19-2011, 11:41 AM
michal@
michal@'s Avatar
Thanks for your help guys.
Now I understand.
2 years ago i bought a Z303 cam. I installed it my first engine to 5.0 in 1994.
Then I checked the clearance, the piston-valve (0.050 ")
modifications, AFR 185cc heads (58cc), Edelbrock RPMII, 1.6 rockers, exhaust FlowMaster 2x 2.5 ", Mac shorty 1.5 / 8 headers .......
On the dyno result;
Horspower, 335 HP @ 5,791 rpm on the flywheel.
Torque, 459NM (340 lb-ft) @ 4205 rpm
max rpm 6778
the engine worked very well, just 5000 rpm up oil leak from dipstick tube.
Unfortunately, the pistons were cracked between the first and second ring, but the engine run until the endI killed him with high rpm
Now I have a 5.0 engine 302 of 1988 lx (forged pistons), unfortunately, cutting the pistons are smaller than those of my previous engine.
Go back 2 *, or undercut the piston?
dynograph look looks good?
[IMG]
[/IMG]
michal@ is offline
Old 01-19-2011, 01:25 PM
AdderMk2
Banned
AdderMk2's Avatar
flycut the pistons
AdderMk2 is offline
Luke9222
10-22-2015 11:55 PM
ctgreddy
09-20-2015 08:35 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
ryland
09-13-2015 12:35 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Z303 cam problem
