max cam lift and duration with stock set-up?
#21
of course it hasn't, the same could be said for tons of other cams, they work in and as far as the term goes to say that they all open and close the valves and allow the car to run...................I'll never forget my buddy after running his 90 gt at the track after a full h/c/i upgrade, = afr 165's ,rebuilt 306, e-cam, and iirc a ported cobra intake, best he could muster was a 13.3 @ 103/104.....needless to say he was not happy, at the time I had stock heads, small performer flat tappet cam and performer 289 intake and I was running 13.4's @100.....he expected to smoke me, and believe me I have more of these same stories from other friends, they were all the same happy and touted the frpp cams until they saw there was more out there, heck if all you ever ate in your life were the bugers at McDonalds then of course you might not know there are places out there that make far better burgers, do they cost more and taste better?? of course....in this world you get what you pay for
But ur post are dead on +1 from me!
#25
Performance is also partially based on preference... But it's all good, I understand all that you are saying (no, really, I do). I was simply passing on the e-cam's acceptance for a vehicle that is going to be daily driven (which seemed to be more of the OP's speed).
I personally wouldn't run an e-cam, I was sort of eluding to the fact that if he wanted to daily his car, that he probably shouldn't bother replacing his e-cam unless he really wanted to go through the hoo-hah...
Personally, my budget is much different, I won't be going for one of the FRPP cams unless I get back on the BDX (Barber Driving Experience) binge again.
#26
please dont give out any more advise.
OP, the E-cam is a horrible choice.
You should consider investing in a new shortblock, something with pistons that are notched for inline valved heads. then get yourself a decent set of heads (if budget allows). If you cant afford them, grab some GT-40 irons and select a GOOD cam. hell, even the TFS1 would be a better choice.
I'm running an e303 now. Speed pro pistons, E7 heads, Very stiff beehive valve springs from comp., and a double roller timing chain. Plus you'll need a rocker arm shim kit if you have the stock 6.25" push rods. It'll lope and you'll notice a big difference from stock. Did it on a 300 dollar budget.
#30
Sorry, don't know the whole story on why he was banned. It couldn't have been because of his polite, courteous, to the point answers and comments. Which, to be honest, I kinda enjoyed reading. He knew mustangs in and out that's for sure, but you needed thick skin if he answered your thread with a commonsense question. Maybe someone will chime in here and tell the story, I'd like to know too.
musnicki
09-23-2015 07:11 AM
