idle issue
idle issue
when i first turn my car on my rpms drop and it turns of unless i give it a little bit of gas but once i got it running for a while if i turn it back on it wont repeat the problem what could this be
thanks
thanks
idle rpm
What is your idle rpm when your engine is warmed up and able to idle on its own? I would disconnect the negative battery cable for 1/2 hour, then turn the idle screw clockwise between 1/8 and 1/4 turn, reconnect negative cable and run the car for a few days, it takes time for the computer to relearn and see if this helps. It sounds like your on the threshhold of idling and stalling so a little turn of the idle screw might be your solution.
clean the idle bypass value, if not the fix replace the TPS on top of the TB. 90% of the time this fixes unless heavy abuse. Did have a car on time work when cold, not start when warmed up....it was both 02 sensors.
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
