Sequential Injection With MegaSquirt - Coil-on-Plug vs. Distributor
So I've been doing research into how to get my MS3X expansion card to do sequential injection for my Dart SHP based 347 stroker that's going into my Fox this spring/summer. I've got the MS assembled, and am currently scraping together the rest of the components that I need to get this build done - basically just the fuel & ignition components.
My hangup right now is on the ignition. The stock-style TFI distributor cannot properly trigger the MS due to the lack of cylinder 1 identification. None of the aftermarket 302 distributors that I can find with an appropriate triggering mechanism provide electronic advance, though, so even if I can get the right triggering signal into my MS, I can't use it to control spark advance and then the point is largely lost.
Digging further into the possibilities I've stumbled across the EDIS setup used in Explorers with 302's. I'm wondering if I can use an Explorer camshaft position sensor to send the trigger signal to the MegaSquirt, and then do a coil-on-plug setup. With the MS3X expansion board, there are enough outputs to support both sequential EFI and coil-on-plug.
Does anybody have advice for me on this front? I would welcome both suggestions for MegaSquirt-friendly 302 distributors, and the right hardware to get a nice coil-on-plug system going.
Thanks!
Thanks!
It's looking more and more like the economical way for me to do this is with an Explorer cam position sensor and mod motor COP components. It'll probably end up being a bit cheaper, too... Explorer CPS is like $75 new.
I also found this featured Fox with COP ignition on 5.0 Mustangs & Super Fords:
http://www.mustang50magazine.com/fea...ski/index.html
There are some good pictures in there that show his setup... it looks like he's running with the Explorer CPS and mod motor coils. Looks like he had to fabricate some custom bracketry to mount the coils (not to mention the custom harness, but in my book wiring up a harness is easier than fabricating brackets).
he's active over on the corral, not so much here anymore :
https://mustangforums.com/forum/memb...85-r-barn.html
but search his threads here
I ended up buying a DFI Dual Sync dizzy after finally figuring out that's what I needed from lots of research.
TrimDrip, I believe that the stock computer operates in batch mode? I'm not 100% sure about that. I do know that you can't get #1 identification from a stock distributor without modifying it.
I've got about $1300 left in parts that I need to complete this build, mostly odds and ends. I'll be sure to post up my experience once I'm done.
good luck with the megasquirt. I ended up getting rid of mine after getting fed up with the lack of relevant support.
I love J3 tuners!
I already picked up the Dual Sync, otherwise I'd just go ahead and check out the MS3 source code, and see if I could write a module to process the input from the TFI dizzy. Being a computer scientist as well as an engineer has its virtues .
