Runs rich and won't idle
Hey all, I just installed my new/used Explorer intake in my 95 GT. Before I installed it, my car ran like a top, purred "like a kitten till the lake pipes roar." I have the stock computer with these mods already:
Headers/exhaust
B303/1.7s
190lph fuel pump
Adjustable FPR
24# injectors
76mm MAF calibrated to injectors
70mm Tbody
CAI
Stock heads, ported, oversized valves
New in the car today: Explorer intake
The only thing I changed was the intake, and I made sure I plugged all the right vacuum lines on it that are not used on the Mustang. I triple checked my firing order, all sensors are plugged in, and I couldn't find and vacuum leaks with my mechanic friend. Timing is sitting at 10 degrees BTDC right now, and still the car runs richer than I have ever seen, and won't idle. My first thought is that the stock ECU can't handle the incoming air. Please help a brother out! TIA, guys,
Tyrell
Headers/exhaust
B303/1.7s
190lph fuel pump
Adjustable FPR
24# injectors
70mm Tbody
CAI
Tyrell
RE: Runs rich and won't idle
OK, this morning I double checked that my fuel harness is connected properly, and it is. There is one thing Im not sure about, I have 2 vacuum lines, a red one and a green one, that run together towards vacuum connections on my elbow adapter right before the tbody. I didn't pay attention when I was pulling them off which line goes to the elbow adapter on the intake, and which one goes to the EGR. Can anyone tell me which is which?
OK, it seems like the only thing that could have changed while I was replacing my intake is the timing. I supose it's possible that while I was finding TDC on #1 with my distributor loose, that my distributor skipped a gear. Is it possible for this to happen and still twist the distributor till I get good timing?
