brake troubles
brake troubles
recently ive noticed that my fox has had a problem with its brakes
when you hit the brakes, the car will pull left, it seems to me like the drivers side caliper is closing more than the pass side. when i did the pads a short while ago, it did seem like the DS pads were a bit more worn than the PS side, but it didnt pull then... so i think it got worse.
what could be wrong? would it be the distribution block beneath the Master cylinder? bad MC? a bad caliper or something as simple as needing a bleed.
i do have a spare set of NOS calipers lying around somewhere just in case they are bad...
It sounds like a sticking caliper, bleed the front really really really well and see if the problem improves, you may need to throw another set of calipers on it if that doesn't solve the problem.
My car does the same thing, its from the car sitting for too long before I bought it and the left front caliper is seizing as it travels
Before you go throwing parts at it take the brakes apart and clean and lube the slides that the caliper rides one. Siezed slides can cause the car to pull cause the pads are riding closer to the rotor and applying a little bit sooner on that side. If all is free and the slides are clean then I would replace the caliper on the side that it is pulling towards.
gotcha, thanks guys ill prolly get to it some time this weekend. supposed to be in the high sixties
and worst case i already have a spare set of calipers,, so swapping them out would just cost me some brake fluid...
Check for worn steering and suspension parts. Caliper slides and contact ends of pads should be lubed with caliper grease. Does car pull left without brakes applied? Partial collapsed brake hose is a check after opening bleeder and pushing piston in with no resistance. Don't forget the Shadetree Motto..."If your car don't stop good let us break it, breaks are our speshulty." Little humour.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
