AC Clutch Installation - Need Help
Old 02-19-2011, 04:46 PM
JimB3
JimB3's Avatar
Default AC Clutch Installation - Need Help
I'm replacing the ac clutch on my '94 GT conv. I'm having problems installing the new clutch hub onto the shaft. AutoZone gave me two different installer tools, but neither one worked. What type of installer tool do I need to get it installed onto the shaft?
JimB3 is offline
Old 02-19-2011, 06:58 PM
Bubba 95SN
Bubba 95SN's Avatar
Seems I remember a bolt in front remove. Remove clutch plate, screw driver between field and plate. Look inside field(with hub bearing) there is a snap ring, remove. Install is reverse. Do not get happy with tightening that little bolt in front. You will break shaft. Only like 100 inch pounds. Someone come on in with the right torque.
Bubba 95SN is offline
Old 02-20-2011, 08:32 AM
JimB3
JimB3's Avatar
There are three parts - the inside (first one installed) is the ring that has the wiring plug on it. I have installed that without a problem. The next part is the pulley, which has a bearing at the center. That is the one I'm having a problem getting onto the shaft. I can't find an installer tool that will fit. There is a small screw hole in the center of the shaft (the third part - the plate, attaches with a small screw). I'm not sure if it would damage the shaft if I tapped on the pulley to get it onto the shaft. There has to be a tool somewhere that will work to install the pulley onto the shaft. Any help out there?
JimB3 is offline
Old 02-20-2011, 12:56 PM
sjd3021
sjd3021's Avatar
check auto zone or advanced auto, i borrowed ac clutch r&r tools from them
sjd3021 is offline
Old 02-20-2011, 03:39 PM
JimB3
JimB3's Avatar
Tried several tools from AutoZone. None of them will work. The only thing for a tool to fasten to on the shaft is with the screw hole that the screw fits in while installing the clutch plate. None of the tools would attach through the hole.
JimB3 is offline
Old 02-21-2011, 02:19 PM
sjd3021
sjd3021's Avatar
i did my ac clutch, pulley & coil, if i remember correctly everything went on the shaft smooth, maybe something is wrong w/ the pulley hub or the shaft of the compressor.
sjd3021 is offline
mtgldr
02-03-2024 09:00 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: AC Clutch Installation - Need Help
