a t-5 shift fork "?"
Old 08-25-2005, 04:08 AM
fast plan
fast plan's Avatar
Default a t-5 shift fork "?"
well it's kind of a dumb question, but i just want to make sure before i put the trans back in......on the shift forks, is all you have to do is line the whole up on the end of the shaft straight up and down and then put the shift forks on to the gears? or is there some kind of weird method? i just don't want to put this in and it not shift properly.
let me know if you can.....i know my explanation isn't quite right but i don't know all the part names.
fast plan is offline
Old 08-26-2005, 02:00 AM
71455olds
71455olds's Avatar
Default RE: a t-5 shift fork "?"
I am trying to remember what I did when I put my trans backl in bit ir was not hard the thow out bearing goes around the input shaft & the fork goes on the pivit point there was only one way that felt right I dont think you have to worry
71455olds is offline
Old 08-26-2005, 03:37 AM
fast plan
fast plan's Avatar
cool thanks man. i messed with it earlier and got it right on.
Old 08-26-2005, 04:07 PM
99saleen351r
99saleen351r's Avatar
ORIGINAL: 71455olds
Say what??????Hes talking about the shifter forks not the clutch forks[&:]And he thought you just helped him[:-]The shifter fork will only slide in in one spot on the gears put it on and see if it shifts fine while its out of the car if it does its right
99saleen351r is offline
Old 08-27-2005, 05:08 PM
fast plan
fast plan's Avatar
oh...i already had it fixed before anyone even replied to this thread...i as saying thanks for the reply in general.
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
ccdguy
09-19-2015 05:20 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: a t-5 shift fork "?"
