Gear Drive Help!!!
Old 03-04-2011, 12:39 AM
Boosted5.0L
Boosted5.0L's Avatar
Default Gear Drive Help!!!
Do any of you guys have a gear drive on your car? I'm running into a little problem with mine, The instructions from comp lack information. The problem i have with mine is with the thrust plate, when the thrust plate is bolted into place, the cam gear only sits about half way onto the dog bone. When i have the thrust plate off, everything is perfectly aligned. How important is the thrust plate? to me it just looks like an over thought oiling issue. does the thrust plate play any important roll as of keeping the cam from shifting around?
Boosted5.0L is offline
Old 03-04-2011, 12:45 AM
86 5.0L
86 5.0L's Avatar
yes. but take a look at this thread. some come with a bearing.
http://forums.corral.net/forums/5-0-...ing-chain.html
86 5.0L is offline
Old 03-04-2011, 01:10 AM
Boosted5.0L
I'm not doing a timing chain, and i dont have the Torrington bearing that they are talking about, the only bearings are the 2 in the dogbone, The cam gear slides onto the cam and the problem i am having is with the thrust plate and finding out the importance of the thrust plate. And maybe some consider the pin that goes through the cam gear into the cam a bearing. but correct me if i am wrong, this is my first time doing a gear drive timing and its screwing with my head and i could use all the help i can get
Old 03-04-2011, 01:28 AM
AdderMk2
Banned
AdderMk2's Avatar
Throw the geardrive in the trash and get a good quality double roller chain. You will thank us later when your valvetrain is still intact, and your cam hasn't been destroyed by the harmonics that the geardrive will cause.
AdderMk2 is offline
Old 03-04-2011, 01:37 AM
Boosted5.0L
i just pulled off a quality double roller since it had over an inch of play.
Old 03-04-2011, 07:58 AM
AdderMk2
Banned
AdderMk2's Avatar
well, put a new one back on it. Gear drives are a BAD choice!
AdderMk2 is offline
Old 03-04-2011, 11:03 AM
Flyingpants
Flyingpants's Avatar
Hey boosted keep us posted on how the gear drive comes out. I know I want to use one in the future, I think they're bada$$.
Flyingpants is offline
Old 03-04-2011, 11:14 AM
j3rry
j3rry's Avatar
only reason some people like those is cause of the sound . jus run ur power steering low and save ur motor lol
j3rry is offline
Old 03-04-2011, 12:49 PM
Boosted5.0L
have you had bad luck with a gear drive? even though you say not to run it, i'm probably going to still end up putting it on. If its screws up i guess you'll have the last laugh in the end
Old 03-04-2011, 01:16 PM
.boB
.boB's Avatar
You need the thrust plate. It does direct oil. But, more importantly, it keeps the cam in the right place. Once installed, the thrust plate sits between the front face of the cam, and the rear face of the cam gear. I don't recall the exact amount of end play there, but it isn't much.
.boB is offline
Nick Oliver
10-17-2018 04:22 AM
StalkerGT
09-25-2015 02:41 PM
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Gear Drive Help!!!
