Clutch starter saftey switch
Old 08-25-2005, 04:30 PM
tw3ak
tw3ak's Avatar
Default Clutch starter saftey switch
A couple years ago a friend and I did a aod to t5 swap. I installed the clutch pedal and I found what I think is the wires for the clutch saftey switch. I plugged them in. It seemed like they didnt snap all the way in. I dont know. Is there anything specail I need to do to make the switch work correctly? and when starting do you need the clutch in at all times or can u be in nutral with the clutch out and start it?
tw3ak is offline
Old 08-25-2005, 07:34 PM
wildstang87
wildstang87's Avatar
Default RE: Clutch starter saftey switch
it should only start with the clutch pedal all the way in. unless you jump the switch then you could crank it in any gear without the clutch, which can get dangerous.
wildstang87 is offline
Old 08-26-2005, 12:40 AM
tw3ak
tw3ak's Avatar
that really doesnt answer my question. Im asking when u do a t5 swap what all do you need to do to make the saftey switch work. Just plugin the 2 wires?
tw3ak is offline
Old 08-26-2005, 01:23 AM
71455olds
71455olds's Avatar
I hate the switch cars did not have it till the mid 80's & I did fine without it for years .
I have mine jumped
71455olds is offline
Old 08-26-2005, 01:48 AM
sick95gt
sick95gt's Avatar
I think that's all you need to do. Does it not react how it should? I probably would guess that you tested it by seeing what happens with it plugged in and with it unplugged. I bypassed mine by cutting them and twisting it together to bypass the switch for a remote start system. It will start without the clutch it. And yes, I triple check that it's in neutral everytime I get out of the car. And I have a switch to turn off the remote start just incase someone else messes with it or needs to drive it. Hold, on, did I say, "incase someone else needs to drive it"??? Yeah right. What the hell was I thinking....
sick95gt is offline
Old 08-26-2005, 04:12 AM
tw3ak
tw3ak's Avatar
It starts with the clutch out if its pluged in or not. I want it to work. I dont want to bypass it
tw3ak is offline
Old 08-29-2005, 04:44 PM
tw3ak
tw3ak's Avatar
bump!
tw3ak is offline
Old 08-30-2005, 03:35 PM
99saleen351r
99saleen351r's Avatar
ORIGINAL: 71455olds
I have mine jumped
You cant race at any track without that working
99saleen351r is offline
Old 08-30-2005, 05:01 PM
sick95gt
sick95gt's Avatar
why not
sick95gt is offline
lincolnshibuya
07-05-2020 03:05 AM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
logan409
09-26-2015 07:43 PM
Quick Reply: Clutch starter saftey switch
