Leak at back of engine, can I do compression test on non-running engine?
The engine on this 91 I just got is wet with fluid (looks like coolant) all over the back of the engine, starting at the rear two plugs (plugs 7 & 8) and going back from there. I've got the car to crank but it won't start. I haven't tracked down why yet but I want to do a compression test. Since it doesn't run, what do I need to do to complete the compression test? I'm pretty sure it will test while cranking but do I need to oil the cylinders or do anything else?
you dont put oil in the cylinders until you find low compression in one of them. The oil is not part of the test, its a way to troubleshoot if the reason the cylinder was low on compression is due to bad rings, or a cracked/hung valve
The engine doesn't need to start. Just let the piston come up twice on the test.
What I would do is take the plugs out of the engine and blow out the cylinders with air. If a lot of coolant comes out, you got problems. Also after all the coolant is out of the cylinders, the engine may start.
ShaneB26154
35
03-04-2021 04:05 AM
