Bad Idle still. Can anyone help me?
I have an 89 gt that will not fire without giving it gas. It turns over but will die if I don't rev the engine to keep her going. The idle flucuates and then steadies out. My gas mileage is terrible. I dont know where to go from here. I have replaced the TPS and cleaned the IAC. MAF has been replaced. Plugs and wires. Fuel filter. I cleaned the throttle body plate. Adjusted the timing. New O2 sensors. I am running out of options. Any ideas?
RE: Bad Idle still. Can anyone help me?
Check for leaks like 8719 said
Then add some fuel cleaner if you haven't done that already...
Still having problems then disconnect the batt for 30 mins then plug it up. Maybe the computer is glitchy......that is if 89s have MAF not speed dense
KingRando
10-02-2015 08:06 AM
