haromic balancer install
hi everyone i was just wondering the easiest way to install the balancer by using a haromic balancer install tool and can use washers as a base because the bearing and nut go into balancer or can i use a rubber hammer and just bang it on or use the center bolt to install it later
jaw? Any harmonic balancer remover I've used was similar to a steering wheel puller, wont he just end up breaking the old balancer and have to use a jaw puller twice? Just sounds a little strange to me, though its not really a big deal if he's replacing it I suppose
To install it, a lot of times you can just use the center bolt to pull the balancer back on, but if need be use a rubber mallet on the center to knock it in enough to use the center bolt. Avoid blows to the outside of it, and don't use any kind of metal hammer.
09-10-2015 08:39 PM
09-08-2015 11:50 AM
